Planas I-6
http://realspeed.co.kz/ - 398.15 Kbps
http://wugnet.com/myspeed/speedtest.asp - 1,38 mbps
http://www.takas.lt/dsl/ - JŪSŲ TESTO REZULTATAI - 1.7 Mbps
pingai i
www.parabole.lt, atlikti dabar:
Reply from 84.32.163.19: bytes=32 time=63ms TTL=253
Reply from 84.32.163.19: bytes=32 time=76ms TTL=253
Reply from 84.32.163.19: bytes=32 time=42ms TTL=253
Reply from 84.32.163.19: bytes=32 time=127ms TTL=253
Reply from 84.32.163.19: bytes=32 time=32ms TTL=253
Reply from 84.32.163.19: bytes=32 time=296ms TTL=253
Reply from 84.32.163.19: bytes=32 time=255ms TTL=253
Reply from 84.32.163.19: bytes=32 time=256ms TTL=253
Reply from 84.32.163.19: bytes=32 time=485ms TTL=253
Reply from 84.32.163.19: bytes=32 time=274ms TTL=253
Reply from 84.32.163.19: bytes=32 time=406ms TTL=253
Reply from 84.32.163.19: bytes=32 time=306ms TTL=253
Reply from 84.32.163.19: bytes=32 time=209ms TTL=253
Ping statistics for 84.32.163.19:
Packets: Sent = 13, Received = 13, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 32ms, Maximum = 485ms, Average = 217ms
