Parabloes internetas vel luzineja...
- Fire-Strip
Tik spejau itanium posta perskaityt, 4 karta dingo, po to po kazkur pusvalandzio rasau, here we go again, 5 kartas weee... Nu tai siaip ne taip is 3 karto parasiau
O tuose elektros tinkluose nezinau kad per loxai dirba, krc savsiem nasarnikai **, pinigus lupa is zmoniu, o iranga kokia? F$%KING PIECE OF $H!T. Tai kas butu jei gera audra uzeitu? Ciuju menesi be elektros butume. Nu ir subiesino, nespeju scandisko leist, gruzas tolka tak
Pinginta www.parabole.lt , ***et tipo normalu viskas? cia nuo sestadienio tox sudas.
Pinging web1.parabole.lt [84.32.163.19] with 32 bytes of da
Reply from 84.32.163.19: bytes=32 time=1079ms TTL=253
Reply from 84.32.163.19: bytes=32 time=32ms TTL=253
Reply from 84.32.163.19: bytes=32 time=2780ms TTL=253
Reply from 84.32.163.19: bytes=32 time=33ms TTL=253
Reply from 84.32.163.19: bytes=32 time=253ms TTL=253
Request timed out.
Reply from 84.32.163.19: bytes=32 time=213ms TTL=253
Reply from 84.32.163.19: bytes=32 time=14ms TTL=253
Reply from 84.32.163.19: bytes=32 time=1411ms TTL=253
Reply from 84.32.163.19: bytes=32 time=107ms TTL=253
Reply from 84.32.163.19: bytes=32 time=346ms TTL=253
Reply from 84.32.163.19: bytes=32 time=54ms TTL=253
Reply from 84.32.163.19: bytes=32 time=135ms TTL=253
Reply from 84.32.163.19: bytes=32 time=942ms TTL=253
Reply from 84.32.163.19: bytes=32 time=59ms TTL=253
Reply from 84.32.163.19: bytes=32 time=96ms TTL=253
Reply from 84.32.163.19: bytes=32 time=126ms TTL=253
Reply from 84.32.163.19: bytes=32 time=1611ms TTL=253
Reply from 84.32.163.19: bytes=32 time=31ms TTL=253
Reply from 84.32.163.19: bytes=32 time=203ms TTL=253
Reply from 84.32.163.19: bytes=32 time=1859ms TTL=253
Request timed out.
Reply from 84.32.163.19: bytes=32 time=2817ms TTL=253
Reply from 84.32.163.19: bytes=32 time=151ms TTL=253
Reply from 84.32.163.19: bytes=32 time=205ms TTL=253
Reply from 84.32.163.19: bytes=32 time=502ms TTL=253
Reply from 84.32.163.19: bytes=32 time=1553ms TTL=253
Reply from 84.32.163.19: bytes=32 time=418ms TTL=253
Request timed out.
Reply from 84.32.163.19: bytes=32 time=1394ms TTL=253
Reply from 84.32.163.19: bytes=32 time=403ms TTL=253
Reply from 84.32.163.19: bytes=32 time=2983ms TTL=253
Reply from 84.32.163.19: bytes=32 time=27ms TTL=253
Reply from 84.32.163.19: bytes=32 time=202ms TTL=253
Request timed out.
Reply from 84.32.163.19: bytes=32 time=265ms TTL=253
Reply from 84.32.163.19: bytes=32 time=527ms TTL=253
Reply from 84.32.163.19: bytes=32 time=453ms TTL=253
Reply from 84.32.163.19: bytes=32 time=49ms TTL=253
Reply from 84.32.163.19: bytes=32 time=272ms TTL=253
Reply from 84.32.163.19: bytes=32 time=68ms TTL=253
Reply from 84.32.163.19: bytes=32 time=118ms TTL=253
Request timed out.
Reply from 84.32.163.19: bytes=32 time=965ms TTL=253
Reply from 84.32.163.19: bytes=32 time=21ms TTL=253
Reply from 84.32.163.19: bytes=32 time=228ms TTL=253
Reply from 84.32.163.19: bytes=32 time=3527ms TTL=253
Ping statistics for 84.32.163.19:
Packets: Sent = 48, Received = 43, Lost = 5 (10% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 3527ms, Average = 665ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
