ping'ai
Smauglys
ping'ai
Post by Smauglys »
Cia tipo normalus pingai??? Saunuoliai kad sugebejot greicius pakelti, del ju nesiskundziu, bet pingai tai ..... gal pagaliau ka nors darysit. Klausimas: kodel jie tokie dideli ar kad optikos nera, ar kad su tiekejais negerai kazkas? pinginau pries 5 min. ir pastaruoju metu pastoviai taip, jokiu papildomu programu kurios naudotu rysi nera paleistos.
Ping statistics for 212.59.18.14:
Packets: Sent = 97, Received = 95, Lost = 2 (2% loss),
Approximate round trip times in milli-seconds:
Minimum = 36ms, Maximum = 928ms, Average = 271ms
TRIUMF
Post by TRIUMF »
Jo, kazkaip cia idomiai.. aisq as nelabai suprantu apie tuos ping, bet... greitis lietuvoj 1280kbps o pingai panasiai kaip ir buvo(tikrai ne mazesni)... :roll: kamine reikalas?..
Ar
Post by Ar »
--- 212.59.18.14 ping statistics ---
42 packets transmitted, 42 received, 0% packet loss, time 41102ms
rtt min/avg/max/mdev = 23.826/40.662/84.967/15.433 ms
Lizard
Post by Lizard »
Pinging 212.59.18.14 with 32 bytes of data:
Reply from 212.59.18.14: bytes=32 time=339ms TTL=119
Reply from 212.59.18.14: bytes=32 time=69ms TTL=119
Reply from 212.59.18.14: bytes=32 time=610ms TTL=119
Reply from 212.59.18.14: bytes=32 time=76ms TTL=119
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 69ms, Maximum = 610ms, Average = 273ms
o cia paraboles viduje...
Pinging web2.parabole.lt [213.226.146.24] with 32 bytes of data:
Reply from 213.226.146.24: bytes=32 time=226ms TTL=62
Reply from 213.226.146.24: bytes=32 time=80ms TTL=62
Reply from 213.226.146.24: bytes=32 time=101ms TTL=62
Request timed out.
Ping statistics for 213.226.146.24:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 80ms, Maximum = 226ms, Average = 135ms
OK thats it... paraboles abonentams pabreziu PARABOLES CS SERVE pingai wirsh 300..... Ka kalbeti jej prisijungiau D2 i monster serva - !600 Ping ... O jungiausi ir i europa... Kicked due to high ping [ 1672ms ]
Fire-Strip
Post by Fire-Strip »
Na ka, reik tiketis kad ten pakeis arba siaip sutvarkys savo yranga, kuri gebetu aptarnaut ir didesni kieki abonentu tokiu pat nasumu..
Lizard
Post by Lizard »
Arba kad trenks zaibas y parabole ir pagaliau baigsis shita nesamone kuria mes wadiname internetu ir widiniu tinklu...... :D
Dr4GuL4
Post by Dr4GuL4 »
nu ir tada meganetas gaus ~1000 naujų abonentų ir pareis visa jų įranga, bus blogiau nei parabolėj
itanium
Piktasis
Piktasis
Post by itanium »
Niekas tokiuose reikaluose nenutinka per diena, viskas pamazhu arba zhemyn ritasi arba aukshtyn lipa... Jei priesh pora metu menesiais stabiliai viskas eidavo tai dabar kiek zhiuriu po savaite net nebeishtempia, vis nauji gedimai/nesklandumai ir nauji skundai forume... Nors chia gal viskas i tai atsiremia kad vasara, atostogu metas :roll: ...
Lizard
Post by Lizard »
Itanium imkim papuolei i avarija.. tave atveza draugiskas zmogus i ligonine o ligonines priimamajame pasako.. Mes atostogaujam... :D
Atejo paraboles abonentas.. laba diena jusu "Super" paslaugos pas mane nesamones daro.. Aciprashom mes atostogaujam.. ateikit mazhdaug po puses metu kai busim bankrutave tada gal kasnors pades.... :D
Cia irgi tas pats.. jei noredamas pasitikrint sawo VB saskaita turi puswalandi periodiskai po 5 minutes laukti po kiekwieno skaiciuko iwedimo kas anksciau praeidawo per 5 o ne per 30...
itanium
Piktasis
Piktasis
Post by itanium »
Lizard, ash visom keturium uzh tave :) ...
Shiaip tik pilstau ir bandau rast kazhkokia pateisinama priezhasti, nesinori galvot apie blogiausia :arrow: kad jie dabar sedi pilvus ishverte ir jiem niekas nebeidomu :roll: ...
Lizard
Post by Lizard »
Itanium :arrow: pac stepas jau kiek laiko nesirodo forume.. Kodel? Gal jam Interneta atjunge? :D :lol: :lol: :lol: ar bijo buti uzhmetytas virtualiomis plytomis? :D Krc ateitu paaiskintu kas daros.. cia montenis 2 arba 3 zodzius (3 zodziai - trigrashis :D ) ikisha "paaishkindamas" viska apie tai ko nereikia... :twisted: Gal rimtai aiti i paraboles bustine pashneket... :D paprashyt optinio kabelio pac nusitiesiu :D
Lizard
Post by Lizard »
Lizard
Post by Lizard »
Parabole kalta ne ash... :P uzh tas 3 zhinutes
Smauglys
Post by Smauglys »
Lizard, pratrinti man rodos gali savi zinutes. Hehe jeigu net komisarui tas pats:
http://board.parabole.lt/viewtopic.php?p=106729#106729
Kim
Post by Kim »
. trint lauk
