Upload speed
Rafarin
Post by Rafarin »
:mrgreen: Start -> Run -> cmd
:twisted:
Fire-Strip
Post by Fire-Strip »
Ir tada rasai "ping web1.parabole.lt" :mrgreen:
Dr4GuL4
Post by Dr4GuL4 »
Sony, start>run, parašai be kabučių "cmd.exe", tada rašai "ping", padedi tarpą ir parašai saito, kurį pingini adresą (šiuo atveju web1.parabole.lt)
|5zU1RaW|
Post by |5zU1RaW| »
Ir dedi -t switch'a, kad pingintu >4 kartus
Fire-Strip
Su -t switch'u pingina tol, pakol paspaudi CTRL+C. Paspaudus tada parodo visus rezultatus.. Kuo daugiau kartu pingina, tuo tikslesnis "average ping" buna.. Pas mane avg. 95ms :(
Code: Select all
Approximate round trip times in milli-seconds:
    Minimum = 13ms, Maximum = 167ms, Average = 95ms
Karys
Post by Karys »
pas mane avarage 5 :roll:
Sony
Post by Sony »
Pas mane tai wa kaip rodo :) visai gerai :P
Code: Select all
  Packets: Sent = 4, Received = 4, Lost = 0 (
  Minimum = 1ms, Maximum = 1ms, Average = 1ms
Dr4GuL4
Post by Dr4GuL4 »
Sony, taj tu gal parabolės pastate gyveni?
Fire-Strip
Arba optika labai tiesiai nuvesta.. :) Pas tave Dr4GuL4 irgi yra optika berods.. O pas tave koks pingas? :roll:
Dr4GuL4
Post by Dr4GuL4 »
Code: Select all
Pinging web1.parabole.lt [213.226.146.19] with 32 bytes of data:
Reply from 213.226.146.19: bytes=32 time=144ms TTL=253
Reply from 213.226.146.19: bytes=32 time=3ms TTL=253
Reply from 213.226.146.19: bytes=32 time=2ms TTL=253
Ping statistics for 213.226.146.19:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Minimum = 2ms, Maximum = 144ms, Average = 37ms
labai įdomus pirmo pingo atsako laikas
Rafarin
Post by Rafarin »
tai visaj normalu tik pas mane buna 1 ir 2 dazniausiai ir >200 :D
:twisted:
Smauglys
Post by Smauglys »
kokie puikus man pingai:
Pinging 213.226.146.19 with 32 bytes of data:
Reply from 213.226.146.19: bytes=32 time=22ms TTL=253
Reply from 213.226.146.19: bytes=32 time=57ms TTL=253
Reply from 213.226.146.19: bytes=32 time=37ms TTL=253
Reply from 213.226.146.19: bytes=32 time=105ms TTL=253
Reply from 213.226.146.19: bytes=32 time=63ms TTL=253
Reply from 213.226.146.19: bytes=32 time=98ms TTL=253
Reply from 213.226.146.19: bytes=32 time=55ms TTL=253
Reply from 213.226.146.19: bytes=32 time=33ms TTL=253
Reply from 213.226.146.19: bytes=32 time=84ms TTL=253
Reply from 213.226.146.19: bytes=32 time=45ms TTL=253
Reply from 213.226.146.19: bytes=32 time=65ms TTL=253
Reply from 213.226.146.19: bytes=32 time=17ms TTL=253
Reply from 213.226.146.19: bytes=32 time=47ms TTL=253
Packets: Sent = 13, Received = 13, Lost = 0 (0% loss),
Minimum = 17ms, Maximum = 105ms, Average = 56ms
|5zU1RaW|
Post by |5zU1RaW| »
Sony turbut localhosta pingino :D
TRIUMF
Post by TRIUMF »
Reply from 213.226.146.19: bytes=32 time=9ms TTL=253
Reply from 213.226.146.19: bytes=32 time=12ms TTL=253
Reply from 213.226.146.19: bytes=32 time=30ms TTL=253
Reply from 213.226.146.19: bytes=32 time=8ms TTL=253
Reply from 213.226.146.19: bytes=32 time=28ms TTL=253
Reply from 213.226.146.19: bytes=32 time=10ms TTL=253
Reply from 213.226.146.19: bytes=32 time=13ms TTL=253
Reply from 213.226.146.19: bytes=32 time=14ms TTL=253
Reply from 213.226.146.19: bytes=32 time=23ms TTL=253
Reply from 213.226.146.19: bytes=32 time=11ms TTL=253
Packets: Sent = 15, Received = 15, Lost = 0 (0% loss),
Minimum = 8ms, Maximum = 37ms, Average = 15ms
optikos nera
upload i uzsieni ~15kb/s i lietuva ~30kb/s
Sony
Post by Sony »
Man parabole skaityk pries langus :) per langa matyti :) gal 100-200 metru ;P o del optikos tai net nezn :)
